Menu Image Resolution - URGENT HELP NEEDED!
COW Forums : Adobe Encore DVD
Raw Sound
on Sep 25, 2007 at 12:09:26 pm
I'm currently in the process of authoring a DVD in Encore CS3 and have designed the menu's using Photoshop CS3. The menu files have the following specs:
1600 x 900 pixels @ 150 pixels per inch
Pixel Aspect Ratio is Square
All the images I have created are crystal clear but when I build a DVD using these images and play it back on any screen be it computer monitor or TV, all backgrounds/buttons etc are blurry and just look terrible.
Can anyone explain why this might be and what is the best solution to rectify the problem?
mike velte
Re: Menu Image Resolution - URGENT HELP NEEDED!
on Sep 26, 2007 at 1:24:08 pm
In Photoshop CS3, begin by creating a new blank file using the Film and Video preset and the the NTSC size.
Add your elements and preview at 100% zoom.
Stick with NTSC safe colors and Sans serif fonts.
Raw Sound
on Sep 26, 2007 at 1:33:54 pm
Sorry, forgot to mention a couple of things...
1. I'm in Australia and therefore use the PAL format
2. The project is in 16:9
Should I just use the DV Pal widescreen settings in Photoshop?
I only ask this as all the text and images still appear distorted.
