Problems in buttons high light.
COW Forums : Adobe Encore DVD
shahram
on Sep 17, 2007 at 5:51:35 am
Hi
I created DVD menu but I have some problems and I don
David Garrett
Re: Problems in buttons high light.
on Sep 17, 2007 at 2:13:32 pm
make sure the HIGHLIGHT layer is selected and then nudge it back into position using the UP/DOWN/LEFT/RIGHT arrow keys on your keyboard.
Also try using a fatter font and see if that reduces the shimmering.
And never use the mouse to test links/highlights/etc.etc as this will give a false representaion.
If you are still having probs with the menu highlights then please feel free to email me the menu to admin@doogs-tutorials.com I will have a look at it for you.
shahram
on Sep 17, 2007 at 9:32:20 pm
Thanks for your reply, I emailed you Background menu.
jenrasmussen
on Oct 17, 2007 at 8:46:28 pm
hi there, wondering if you can help clarify for me. when you nudge the highlight it also nudges the "normal" state effectively rendering no change - any ideas?
Jeff Bellune
on Oct 17, 2007 at 9:30:58 pm
Are you using text buttons? Is Encore creating the highlight from the text?
You need to edit your menu in Photoshop and create a separate highlight layer. Then you can nudge the highlight layer without moving the underlying text.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
jenrasmussen
on Oct 17, 2007 at 10:49:17 pm
i was just coming to the conclusion that i might have to do that. used photoshop text the first time around but i cant remember why i reverted to encore text with subpictures.
have a good one ;) and thanks for the speedy response.
