Butten Routing Problem ( Not the usual one)
COW Forums : Adobe Encore DVD
Chris232
on Sep 11, 2007 at 11:06:09 am
I'm having a problem with button routing however after searching this board It doesn't appear to be any of the usual problems. I have turned on the button routing overlay and made sure everything is how I want it, and made sure none of the buttons overlap, however when I preview they don't perform properly. I have the buttons set out to route as follow
A
B
C
D
E
F
however when I preview, going down through the buttons using the down arrow it skips out C, and going back with the up arrow, it skips out D (but includes C). I've tried everything and can't figure out what
David Garrett
Re: Butten Routing Problem ( Not the usual one)
on Sep 12, 2007 at 11:22:00 pm
open up the menu in Photoshop and then check to make sure that button C and D are both in seperate layer sets, and that they have the correct naming parenthesis.
Chris232
on Sep 13, 2007 at 1:09:28 am
Thanks Dave, after spending a few hours in photoshop I mananged to get it sorted.
