Setting Chapters with multiple video files conundrum.
COW Forums : Adobe Encore DVD
Chris232
on Sep 9, 2007 at 8:02:29 am
I
Jeff Bellune
Re: Setting Chapters with multiple video files conundrum.
on Sep 9, 2007 at 12:31:31 pm
Depending on your source material, render each of the 9 projects out separately to DV .avi files (or uncompressed .avi files), then import the 9 .avi files into a project.
Once the .avi files are added to the project, stitch them together end-to-end in a single timeline and export that as a single .avi file (using the same codec that you used for the 9 files individually).
Import the stitched-together .avi file into Encore and you should be able to author your DVD the way you want.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Joe Bowden
on Sep 9, 2007 at 3:35:34 pm
Perhaps you could put the clips together in another NLE, then export a single AVI for use in Encore.
Otherwise, upgrade to the latest version of Encore.
Chris232
on Sep 9, 2007 at 10:32:09 pm
Thanks for the replys
I was a bit hesitant to add all the .avis to a timeline as I thought another pass through Premiere would degrade the quality.
I don't know enough about how it works though, would the fact that the .avis haven
