Importing m2v
COW Forums : Adobe Encore DVD
Don Holland
Importing m2v
on Sep 7, 2007 at 6:57:48 am
Greetings,
The Encore manual states you can import m2v files, but it seems as Encore wants to re-transcode them. Is there a way to stop that from happening? Imported ac3 files don't get re-transcoded.
Don
Jeff Bellune
Re: Importing m2v
on Sep 7, 2007 at 10:25:11 am
How was the .m2v file encoded? What software was used and what were the encoding settings?
-Jeff
Don Holland
Re: Importing m2v
on Sep 7, 2007 at 11:56:55 am
The files are encoded in Comprssor. Here are the information from th codec:
Name: HD MPEG-2 19.0Mbps
Description: For HD DVD. Fits up to 30 minutes on a DVD-5
File Extension: m2v
Estimated file size: 7.91 GB/hour of source
Type: MPEG-2 video elementary stream
Usage:HD DVD
Video Encoder
Format: M2V
Width and Height: Automatic
Pixel aspect ratio: Default
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls: Automatically selected: Off
Start timecode from source
Aspect ratio: Automatic
Selected 16:9
Field dominance: Automatic
Average data rate: 18 (Mbps)
2 Pass VBR enabled
Maximum data rate: 27 (Mbps)
High quality
Best motion estimation
Closed GOP Size: 1/2 second, Structure: IBBP
DVD Studio Pro meta-data enabled
Jeff Bellune
Re: Importing m2v
on Sep 7, 2007 at 12:00:57 pm
Encore doesn't support HD-DVD encoding - it accepts SD DVD compliant files and Blu-Ray disc compliant files.
For HD-DVD you will need DVDSP.
-Jeff
Don Holland
Re: Importing m2v
on Sep 7, 2007 at 12:42:04 pm
That explains that! Thanks Jeff.
Joe Bowden
Re: Importing m2v
on Sep 7, 2007 at 5:47:07 pm
HD DVD encoded to MPEG-2 should be usable in Encore without re-transcoding - IF you build to Blu-ray. However, if you try to build a DVD, it will get re-transcoded to be MPEG-2 legal for DVD.
George W.
Re: Importing m2v
on Sep 8, 2007 at 10:47:17 am
[Jeff Bellune] "For HD-DVD you will need DVDSP."
You can also go with Ulead's DVD MovieFactory 6 Plus. Pretty good value for "basic' HD-DVD Authoring (imho), and it also includes Blu-ray burning (direct from video source).
Regards,
George
Jeff Bellune
Re: Importing m2v
on Sep 8, 2007 at 11:14:41 am
If he used Compressor, and DVDSP metadata was enabled, then I'm 99.9% sure he's on a Mac. Does Ulead have Mac versions of their software?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
George W.
Re: Importing m2v
on Sep 8, 2007 at 12:07:28 pm
[Jeff Bellune] "If he used Compressor, and DVDSP metadata was enabled, then I'm 99.9% sure he's on a Mac. Does Ulead have Mac versions of their software?
-Jeff"
Nope, I don't believe Ulead has Mac versions of their software. But today, alot more folks have both platforms and/or a Mac running Windows software.
Regards,
George
Don Holland
Re: Importing m2v
on Sep 10, 2007 at 10:10:23 pm
I already own DVDSP and Encore. I am not buying any more software. I am tring to make a Blu-Ray disc. Should I compress my footage with H.264 ratheer than m2v?
