I can't successful install Encore CS3.
COW Forums : Adobe Encore DVD
blue99
on Aug 14, 2007 at 2:55:06 am
I use the tryout version of Adobe CS3 Master Collection before.
Now, I install Encore again and want to activate it.
But, when I open Encore after install Adobe CS3 Master Collection again. It will auto close it.
I can't input the activate code.
Can you tell me the problems?
jkb242
Re: I can't successful install Encore CS3.
on Aug 14, 2007 at 6:53:44 pm
It could be a number of different things in addiion to whether you are using a MAC or PC environment. If you loaded a trial version then did not purchase it or decided to take another route, you will have to completely reomove the original trial version. Assuming this is a PC platform, you will need to get the Adobe Script removal tool from Adobe (free) and follow the instructions carefully, including a second step that involves using the Microsoft deep removal tool which will remove any traces of the former progarm so that you are sure that you are working with a clean install.
Follow the instructions for both the Adobe Script removal and the Microsoft file removal tool very carefully as there is NO return if you are not careful. I experience a similar situation and this worked perfectly!
Good luck.
blue99
on Aug 16, 2007 at 6:12:41 am
Really thanks a lot! I will try to do it.
I think I haven't full clean it.
