How to fix Adobe Encore CS3 Crash ! ! ! READ
COW Forums : Adobe Encore DVD
Rubens Carrilho
on Aug 6, 2007 at 4:21:39 pm
The problem with Adobe Encore CS3 can be fixed just putting a blank dvd media in the drive(s).
I put a blank DVD media in my dvd drives and the startup problems stoped.... but if I remove the media, problem backs again.
Sorry my English
Rubens Carrilho
Computer Graphics Designer
Abel Del
Re: How to fix Adobe Encore CS3 Crash ! ! ! READ
on Jun 2, 2008 at 1:31:24 am
Hi there!, I tried to load a cd/dvd on the drive...did not work!....
After a couples of days I finally hit the jackpot! is how fix the Adobe Encore Cs3 Crash at the beginning..
The Issue was the Windows CD/DVD ASPI drivers for my DVD/CDs drive/s. yes!!!!! encore get stuck on the splash /loading screen when is displaying the "Come for the blu-ray, stay for the flash".
so here is the fix that worked for me:
Before you try anything else, give the latest drivers (version 4.71) from Adaptec a try. They are supposed to work under 98/ME/NT/2K/XP and don't care if you don't have an Adaptec SCSI card installed.
The first thing to check is to make sure that you have a fully functional set of driver files. Adaptec has produced a tool called ASPICHK which will tell you all about the health and version numbers of the drivers on your system. when you unzipped the files inside there is a tool called "aspichk.exe".
then if you are running XP just double clink on the "aspiinst.exe"
, reboot your system and done!!! to ensure that the you new drivers are installed run again the "aspichk.exe".
hope this helps!!! it worked for me like a charm. after trying everything. Adobe Encore CS3 load fast as ever!!! SWEEEET!!!!
Eric Wazirali
Re: How to fix Adobe Encore CS3 Crash ?
on Jun 6, 2008 at 5:55:39 am
Hello guys, Please help me with this. I have Vista 64bit with 4gig ram. When i try to build DVD its crash on me . Please help me this is just driving me crazy. I have lot of work in panding. Here is the error
This is the error code if it will provide any help.
Problem signature:
Problem Event Name: APPCRASH
Application Name: Adobe Encore.exe
Application Version:
Application Timestamp: 46cf7628
Fault Module Name: Adobe Encore.exe
Fault Module Version:
Fault Module Timestamp: 46cf7628
Exception Code: c0000005
Exception Offset: 003fa73c
OS Version: 6.0.6001.
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
Joe Bowden
on Jun 6, 2008 at 6:31:18 pm
Encore CS3 is not supported on Windows Vista 64 systems.
Eric Wazirali
on Jun 6, 2008 at 6:45:36 pm
Hello, But it worked before. Its been working fine. I burned DVD before on this computer. And thanks for your help.
Benoit Dorion
on Feb 22, 2010 at 12:43:15 pm
Have you ever gotten this to work? I'm having the same issue and I also have Vista 64. I'm wondering if I should just get CS4 and open up my CS3 project in there and build it.
© 2018 All Rights Reserved
