System Error 0x00000020
COW Forums : Adobe Encore DVD
DIY
by
on Aug 3, 2007 at 5:24:01 am
When burning a new DVD.
Encore 2.0
All goes well, transcodes etc.. Then I get the below as Encore starts to write files..
"System Error 0x00000020"The process cannot access the file because it is being used by another process"
"Building transitions failed" is quoted on the Build Process dialogue box underneath the banner reporting above message.
I have re-booted etc to no avail..
George W.
Re: System Error 0x00000020
on Aug 3, 2007 at 11:14:57 am
I got a similar error the other day. I saved the project as a new name, then it was able to build the DVD Folders. It might or might not work for you -- but could be worth a shot...
Regards,
George
DIY
by
on Aug 3, 2007 at 6:02:08 pm
Will give it a go and report back.. Many thanks for the tip..
DIY
by
on Aug 3, 2007 at 7:16:00 pm
You are a rockstar... Completly sorted...Only thing is resultant burned DVD has a very tinny soundtrack from one of the timelines. This is strange as it is the shortest of the three. The longest is 1hr15mins, the second longest is 5mins and the shortest is 3 mins. However the former two are fine and the latter sounds as if it is playing through a tiny radio!
Any thoughts..?
