Adobe Encore CS3 crashes
COW Forums : Adobe Encore DVD
cow
manny
on Jul 18, 2007 at 10:05:52 pm
Im using the Adobe Master Collection CS3. Everything else loads up fine but when i tried to open Adobe Encore, it failed. It would appear to launch - I see the splash screen comes up and different plugins being loaded but when the actual interface was about to open, it quits. I tried to restart and launch Encore, same thing happens. The rest of the products like after effects, premiere, illustrator, etc loads up fine it's only encore crashes. Any ideas on how to resolve this? Im using Windows XP Pro with 2G of RAM.
Auscorusant
Re: Adobe Encore CS3 crashes
on Jul 31, 2007 at 10:26:51 pm
Hi Manny,
I have exactly the same problem, Encore goes through the loading process and then when it's just about to launch into the program, it quits.
Would be great if someone could provide an insight into this.
Many thanks!
Rubens Carrilho
Re: Adobe Encore CS3 crashes FIXED
on Aug 6, 2007 at 4:44:34 pm
The problem has been fixed when you put a Blank DVD Media into the DVD drive!
1 - put a Blank DVD Media into you DVD Drive
2 - start Adobe DVD Encore CS3 normally
Works Fine !
Rubens Carrilho
Computer Graphics Designer
Rubens Carrilho
on Aug 6, 2007 at 4:26:56 pm
The problem has been fixed when you put a Blank DVD Media in the DVD drive!
Rubens Carrilho
Iris Moleman
on Dec 5, 2009 at 11:23:37 pm
This didn't work for me. What else can I do?
