not valid mpeg 20402
COW Forums : Adobe Encore DVD
on Jul 11, 2007 at 5:19:21 pm
I was working on a DVD, and when I was about half done I burned it successfully.
Then I added some more files (mpg2 made with my RTX100--same as the earlier files) and also added some motion menus.
Now when I try to create a DVD, I get this error message:
File is not valid mpeg -20402
Is there any way to tell which file is causing the problem? Is it likely the motion menu is causing the problem?
Re: not valid mpeg 20402
on Nov 18, 2007 at 12:35:23 am
I'm having the same problem and confused by the apparently inconsistencies in what will burn and what won't. Have you found any solutions since you wrote? I've tried using ProCoder to output compliant MPEGs with the following but this isn't working either:
program stream
GOP 36field/18frames max
GOP auto
Strict GOP
Scene detect enabled
Audio PCM
16 bits
CBR 8000
on Nov 18, 2007 at 5:07:29 pm
It's been a while since this happened, but if I remember correctly, the avi in my project had something wrong with it. I recaptured the avi and then I got a good mpg from it.
© 2018 All Rights Reserved
