play all/ chapters
COW Forums : Adobe Encore DVD
roenld
play all/ chapters
on Jul 4, 2007 at 2:45:20 am
Hello all!
i have looked through help and manuals and even got some advice for a similar issue here - but it still polagues me.
So i need a play all and a chapters select. i went through and set the chapter markers and set end action for each one but the play all button now executes the chapter end action - this was for both simple chapter markers and after setting up a chapter playlist.
do i need overides or am i missing something?
cheers roen
George W.
Re: play all/ chapters
on Jul 4, 2007 at 10:54:46 am
Instead of using Chapter END-ACTIONS or Overrides, I would setup some Chapter Playlists. Then link to the Chapter Playlist when you only want a single chapter (or several chapters that you can add to a Chapter Playlist).
This should work (unless you have more than ~18 Chapter Playlists).
Regards,
George
roenld
on Jul 4, 2007 at 11:01:14 pm
Thanx George W - i will put that into action!
