Help transcoding 23.976 footage...it just freezes.
COW Forums : Adobe Encore DVD
Josh J. Johnson
on Jun 14, 2007 at 2:28:54 pm
When you import either an asset or timeline it asks you to transcode. But while transcoding it just freezes up? I'm using an avid quicktime ref file. I've used this method before and it has worked? Anybody have any insight on this problem.
SSloan
Re: Help transcoding 23.976 footage...it just freezes.
on Jun 14, 2007 at 7:20:29 pm
I would encode the file out of premiere (or whatever program you edited/captured it in) and then import the finished mpeg2. Never been a big fan of the encore transcodes. Hope that idea helps.
Josh J. Johnson
on Jun 14, 2007 at 7:45:30 pm
I could probally use sorenson I suppose or premier.
thanks
SSloan
on Jun 14, 2007 at 7:52:29 pm
If you have premiere - the encoding engine is the same as Encore's. So, if you like the final quality of the encore engine, it might help with some of the trouble you mentioned.
Josh J. Johnson
on Jun 14, 2007 at 8:16:56 pm
I've never used premiere before how do you transcode in it?
thanks
Josh J. Johnson
on Jun 14, 2007 at 9:09:57 pm
Nevermind found it.
