getting transistions to look smooth...
COW Forums : Adobe Encore DVD
Andyman
on May 17, 2007 at 12:22:09 pm
I'm experiementing for the first time with putting a transition from the main menu to a submenu. Everything seems okay, except when the transition is over, it doesn't smoothly go into the submenu; there's a black flash like it's resetting. In a way that kindof defeats the purpose of having a transition, because there's no smoothness.
Will that always be there? I want the end of the transition to instantly and smoothly become the submenu to which its targeted.
David Garrett
Re: getting transistions to look smooth...
on May 17, 2007 at 1:32:23 pm
is the black frame showing on the Encore Preview??? it should not be so noticeable on the burned DVD..
Andyman
on May 22, 2007 at 2:13:04 pm
Hey, yes, thank you...
The problem is fixed when you burn a DVD. Encore's "Preview" doesn't handle it, but when you burn, it's okay.
