While I'm at it... How do you unlink a file in the flowchart?
COW Forums : Adobe Encore DVD
cruise
on May 15, 2007 at 3:57:12 pm
I seem to be having difficulty unlinking a file in the flowchart after the link has been specified. I've tried deleting the file (in the flowchart) but no luck. There doesn't seem to be an unlink command. I've tried the online help files and just get references to unlinking video and audio -argh!
Thanks again.
Jeff Bellune
Re: While I'm at it... How do you unlink a file in the flowchart?
on May 15, 2007 at 4:47:08 pm
Using the Select tool (which becomes the pickwhip tool while working in the Flowchart), drag from the source of the link you want to delete to the desired new target of the link. The Flowchart panel will refresh to show the new link.
If you want to delete a link but not link to anything new, use the Properties panel for the link source and delete the link there.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
cruise
on May 15, 2007 at 4:56:28 pm
Thanks for the tips!
