Can't get audio on the same track...
COW Forums : Adobe Encore DVD
cruise
on May 15, 2007 at 3:52:50 pm
Hi There,
I'm having an issue where I cannot add another file to the end of my current timeline - or rather, I can, but only video and not audio. If a create an additional audio track, then the audio will show up. I am unable to get the audio for both files on the same track. This is the first time I've experienced this issue and it's very frustrating.
Hope I was clear. Any input would be greatly appreciated.
Jeff Bellune
Re: Can't get audio on the same track...
on May 15, 2007 at 3:55:52 pm
Is the audio perfectly matched to the other audio on the track - format, channels?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
cruise
on May 15, 2007 at 4:03:01 pm
Hi Jeff,
I've encoded my files as .mpg before I imported them into Encore. Interestingly, I'm only having a problem with the most recently encoded file, but as far as I know, I've done nothing differently - same workflow as always - export from Avid, encode and import into Encore.
Are there any specific audio issues that you think might be causing the problem?
Jeff Bellune
on May 15, 2007 at 4:29:28 pm
The first place I'd check is the number of channels - did you export as stereo when it should have been mono, or vice-versa?
Additionally, if you are exporting as a muxed .mpg file, please consider exporting as demuxed, elementary .m2v video and .wav audio files. Things generally go much smoother in Encore when the imported assets are demuxed.
-Jeff
