Bad playback after burn
COW Forums : Adobe Encore DVD
dafulk
on Apr 23, 2007 at 7:38:11 pm
I'm having a strange problem I've never seen before. I've built a project like I always do and played the preview in Encore. It plays back fine. When I burn the DVD it plays back with staggering on some shots. I've tried burning it in different burners and played back on there different machines. The project started out in AVID then to ProCorder for the compression and then to Encore. Any ideas?
Duane
Workerbee
Re: Bad playback after burn
on Apr 27, 2007 at 2:58:07 pm
Hi - Here's my guess. If the motion is bad, it indicates that the MPEG was rendered on the wrong field first. If you're using Sorenson Squeeze, check the settings. It's not a machine problem. The answer lies somewhere in your settings in the workflow.
dafulk
on Apr 30, 2007 at 7:07:27 pm
You are right. It was in the settings. I finally found the problem. I had done a 16 X 9 version of the project earlier and failed to reset the size in the Quick Time to 4 X 3. It's sometimes amazing how many times you can look at something and not see a small error! Thanks for the response.
Duane
