important capacity issue
COW Forums : Adobe Encore DVD
antonis
on Apr 5, 2007 at 9:23:54 am
I have imported a big number of videos which i'm going to use them in two different timelines. How does the Encore sum up the size of the final dvd ..I mean since the videos are the same but are used twice (in diferrent timelines), the final size is going to be the double??
thnx antonis
Joe Bowden
Re: important capacity issue
on Apr 5, 2007 at 1:16:59 pm
Yes, if you put the same video in multiple timelines, then you will increase the size of your project.
If you are using Encore 2.0, look into chapter playlists, which allow you to accomplish the same thing without increasing the amount of disc space used.
