weird error on import
COW Forums : Adobe Encore DVD
ae4life
on Mar 12, 2007 at 7:16:08 pm
ive made a video in After Effects. exported as an mpeg2 file. all is good so far. i work in encore to make a menu, etc. now i try to import the mpeg2 file and i get this error.
The software thats used to decode this software is not available on this system. Installing the correct decoders for the files you are working with may correct the problem...
please help. thanks
David Garrett
Re: weird error on import
on Mar 13, 2007 at 1:46:12 pm
I would just export the file from AE as a .AVI and then import this into Encore and allow Encore to do the encoding... it does a good job...
ae4life
on Mar 13, 2007 at 6:51:35 pm
is it as good of quality. hmmmmm thats my big problem. i want the best resolution
Neil Wilkes
on Mar 13, 2007 at 9:34:02 pm
AVI is far, far better than MPEG-2.
MPEG-2 uses massive compression, AVI is much less.
For absolute highest quality from AE, get hold of the BlackMagic codec & export as 10 bit BlackMagic MOV file.
Encode this to MPEG-2 and import into Encore.
ae4life
on Mar 14, 2007 at 3:55:44 am
where should i bring the mov file too to encode to mp2
do i need to worry about settings such as botrate, keyframing, etc.
Neil Wilkes
on Mar 21, 2007 at 11:16:31 am
You can use any MPEG-2 encoder that will accept a MOV/Quicktime file.
CCE-SP, TMPGEnc Xpress 3 or greater, MainConcept, ProCoder 2 etc.
Alternatively, just import the MOV file right into EncoreDVD 2 and it will deal with it for you automatically. I have found this can do a really good job plus you don't need to think about any settings at all.
