Cache files
COW Forums : Adobe Encore DVD
Mohamed
Cache files
on Feb 16, 2007 at 2:56:57 am
I'm using ENCORE DVD2 and my project size 3.6GB I had less than 40 GB free space, I tried to build image file, it took over an hour building at the end I got error volume is full. I checked space on hard drive I found it full.. I'm freeing more space on hard drive,,, but I noticed that the size of Cache file inside the source file is 34.6 GB
my question is can I delete the cache files.. and would that affect my project. I often get out of memory error.
would I save more space if I build dvd direct to disc. please.
thanks
Moe
Mylenium
Re: Cache files
on Feb 16, 2007 at 7:40:04 am
Have you considered transcoding the sources first? Encore will place backup copies of your original files in the source files folder plus MPEG-II transcoded versions. That's of course going to kill a lot of free space.
Mylenium
[Pour Myl
Mohamed
Re: Cache files
on Feb 16, 2007 at 10:23:31 am
ok, i will try again, and transcoding the sources first, but..is it ok to delete the cache files,,, as they are so big 44.2GB.
and if its ok,, should I delete the whole of cache file or delete Media Cache Files which it is inside the cache file.
thank you
Moe
Mylenium
Re: Cache files
on Feb 16, 2007 at 8:26:09 pm
Only delete the media cache files. Don't tamper with the xml files and the other small files. Encore is able to rebuild a DVD even without them, but some things might get lost (chapter markers, overrides).
Mylenium
[Pour Myl
