Background motion menu won't run
COW Forums : Adobe Encore DVD
seanwinn
on Jan 31, 2007 at 10:19:58 pm
Hi, just posted yesterday questions about inserting video in spots on top of a menu. I received the correction on that thought...THEN created a video that accomplished what I wanted to see and it played, looped fine in Encore....
BUT then I tried to add text in three places that I could convert to buttons and now the background video won't run. I erased the text and it works again....can I get around this?
Thanks for any help!
Joe Bowden
Re: Background motion menu won't run
on Jan 31, 2007 at 10:37:31 pm
Did you try File > Render > Motion Menus?
seanwinn
on Jan 31, 2007 at 11:18:29 pm
Joe, thanks for your help, that did it. One thing though...the text I put in & converted to buttons is not showing any highlight color when I mouse over them in preview...is there a way to get that back?
Joe Bowden
on Jan 31, 2007 at 11:59:30 pm
What version of Encore are you using?
seanwinn
on Feb 1, 2007 at 12:33:23 am
Hi again.. 1.5
Joe Bowden
on Feb 1, 2007 at 12:52:31 am
Select the button, then choose Object > Create Subpicture.
seanwinn
on Feb 1, 2007 at 1:00:38 am
Hey again, tried that on each of the buttons to no avail...they remain unchanged. I figure it has something to do with the fact that they are text converted to buttons over the top of a motion video background.
There is s slight black shadow type affect that appears when you mouse over them, but no color hightlight. So as is, they are kind've hard to read...thoughts?
PS - really appreciate your help
seanwinn
on Feb 1, 2007 at 1:09:49 am
Joe, somehow I got it. Deleted the buttons in Photoshop, recreated the whole process...and I have the normal orange flesh colored mouse over highlight. So it's working.
(now if I can figure out how to successfully change that mouseover color ;)
thanks again so much for your help
John Rich
on Feb 1, 2007 at 2:19:36 am
This might help. Check out the suppicture highlight tutorial at the bottom.
Also the first encore part of Turning Pages.
http://jmrser.com/Tutorials.html
John
JOHNR
David Garrett
on Feb 1, 2007 at 10:31:11 am
Click on the menu and then go up to MENU on the toolbar at the top, and then select "EDIT MENU COLOUR SET" and change the COLOUR SET from automatic to MENU DEFAULT and then change the colours of the highlighted and activated state in the HIGHLIGHT GROUP 1, Then adjust the opacity of each form there also..
