transcode
COW Forums : Adobe Encore DVD
popnerd2002
transcode
on Jan 30, 2007 at 1:53:23 pm
would encore tanscode 30gig of footage to fit on a dvd? i have exported out of premiere in dv format
David Garrett
Re: transcode
on Jan 30, 2007 at 1:59:47 pm
yes it will, Encore will automatically adjust the encoding to fit the video onto DVD, bear in mind the longer the duration the video is then the more the quality will suffer..
typpeo
Re: transcode
on Jan 30, 2007 at 2:00:42 pm
(from the help menu, I pointed this out to you in your last post.)
To calculate a bit budget
Bit budgeting provides a target video data rate for the project. You can either use a pencil and paper to quickly develop one, or you can create a spreadsheet to do the calculations for you.
When bit budgeting for projects to be distributed on 4.7 GB DVDs that contain a single stream of compressed audio, you can use the simplified formula of 560 / x = bit rate in Mbps, where
