Should the menu have an ending task
COW Forums : Adobe Encore DVD
blondie4fun
on Jan 29, 2007 at 8:55:00 pm
I have everything set on Encore DVD 2.0 and am getting ready to burn it out.
I want it all to go back to the menu tabs when it ends? I set the timeline to go back to the first tab name but I notice in the menu properties there is also an ending thing to be set..(I have my own premade menu tabs) Should that also be marked as the first tabs name? ( I did it in my chapters and all that is set just curious about that menu tab one)
Want to get it transcoding but it takes like 6 hours and I messed it up last night so I thought I would ask this time before I start it.
Joe Bowden
Re: Should the menu have an ending task
on Jan 29, 2007 at 9:31:07 pm
Your menu should have an end action only if it has a fixed duration (e.g. either it's a motion menu with a finite number of loops, or you only want it onscreen say 30 seconds, etc.).
If your menu is a still menu, the default behavior is to hold it forever until the user presses a button. In this case, you do not need a menu end action.
blondie4fun
on Jan 29, 2007 at 10:31:17 pm
Thanks so much
That should fix my problem
