Quicktime Reference from AVID Xpress won't transcode in Encore 2.0
COW Forums : Adobe Encore DVD
Surf Dad
on Dec 25, 2006 at 3:13:14 am
Greetings, any thought on why I cannot transcode a Quicktime Reference file that I exported out of AVID Xpress? To make things even more interesteding I exported 5 AT reference files at the same time and all assets imported fine... previewed fine... but 2 of the three would not transcode so I ultimately just exported as QT with an Animation codec. Any help would be greatly appreciated. They were exported as 720x480. Thanks.
Jeff Bellune
Re: Quicktime Reference from AVID Xpress won't transcode in Encore 2.0
on Dec 25, 2006 at 1:11:21 pm
What were the audio settings for the troublesome assets?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Surf Dad
on Dec 25, 2006 at 8:26:38 pm
I exported the audio the same for all. AIFF-C at 48knz, 16 bit. When I exported the second time with the Animation codec, I just synced up the audio that was originally created when I exported the refrence files.
geo
by
on Dec 25, 2006 at 3:51:33 pm
I haven't had much luck bringing QT Refs into Encore, but I almost always do the MPEG encoding via an external application, so it's a non-issue.
If you really want Encore to do your encoding, export as "fast export quicktime" instead of quicktime reference. This won't transcode your data, it will just write it to an external file rather than making a bunch of pointers (references) into your original Avid media. It will export much faster than the Animation codec, and the data will be exactly the same as QT Ref data would have been.
geo.
Surf Dad
on Dec 25, 2006 at 8:31:48 pm
Thanks Geo,
I didn't see the "fast export" option codec when I selected Quicktime as my file type and then format. Any recomended codes other than Animation that will hold the quality? Do you know if MPEG4 would work? I could export as than, but not MPEG2. Thanks.
Brian
Surf Dad
on Dec 25, 2006 at 8:33:37 pm
Sorry fogot to mention. I do have Sorenson Squeeze 4 that I could use for the transcodeing. Any suggested settings for best results?
Brian
geo
by
on Dec 25, 2006 at 9:50:42 pm
Fast Export means the codec is same as source, so you don't select a codec, that's the whole point.
I have Sorenson 4.3, but never use it for MPEG. I looked at the settings, there don't seem to be many of them, I would prefer a little more control. For example, I didn't see a way to tell it whether your rgb colors are in the range 0-255 or 16-235.
geo.
Mylenium
on Dec 26, 2006 at 10:27:33 am
If you are experiencing problems, try downgrading your Quicktime. Avid systems do not work well with QT 7 (for whatever reasons). We were able to heal all our pains by going back to 6.5.
Mylenium
[Pour Myl
geo
by
on Dec 26, 2006 at 4:33:56 pm
That's funny, I have had just the opposite experience. I can't get XPressPro 5.6.x for the PC to work with any release of QT prior to QT 7.
For a while, Apple were bundling iTunes with QuickTime, which was especially annoying. Lately they offer a QT-only installer for cranky guys like me.
geo.
Mylenium
on Dec 27, 2006 at 3:40:49 pm
Hehe, that's indeed strange. But regardless, it's definitely more AVid's fault than it is a QT problem or the other apps. ;O)
Mylenium
[Pour Myl
Beatrix Moersch
on Aug 12, 2009 at 7:07:27 pm
What external program do you recommend? And how to you access the files through this program? QuickTime reference? I tried your fast export method, but I get a "An ACCESS_VIOLATION exception occurred." Each time.
