Encore Shrinks My Video
COW Forums : Adobe Encore DVD
NoForMe
on Dec 21, 2006 at 9:08:42 pm
Hello,
I imported a Mpeg 2 video from Adobe Premiere in 720 x 480 Format. It plays in the timeline great, but when I preview there are 2 large black bars on the top and bottom of the screen, and when I burn I get the same. How do I make it burn full screen? Thanks
Eli
Joe Bowden
Re: Encore Shrinks My Video
on Dec 21, 2006 at 10:06:25 pm
What's the aspect ratio of the clip? And the pixel aspect ratio?
NoForMe
on Dec 21, 2006 at 10:10:33 pm
Well I created it in Premiere at 720*480
Joe Bowden
on Dec 22, 2006 at 12:19:23 am
720x480 could be square pixels, or it could be DV 4:3 or 16:9. Which is yours?
NoForMe
on Dec 22, 2006 at 6:35:23 am
hmmm, I know it's the preset in Premiere for DV 720 X 480. I'm not sure if it's square pixels or not, is there a place I can check?
Joe Bowden
on Dec 22, 2006 at 3:21:17 pm
Check your project settings...all that information should be there, including video codec used, audio bit/sample rate, etc...the more information you can provide, the better. Once we know what kind of file you are trying to use in Encore, we can then make a better assessment of what the problem may be.
NoForMe
on Dec 22, 2006 at 3:51:44 pm
I'm Using
Editing Mode : DV PLayback
Timebase 29.97 Fps
720 X 480 4:3
Pixel aspect ratio - D1/DV NTSC (0.9)
Does this help?
NoForMe
on Dec 22, 2006 at 4:34:09 pm
So figured out what happens, I just don't know how to fix it, When I import the Mv2 into encore it automaticaly switches the timeline to a 16:9 ration, I just don't know why
NoForMe
on Dec 22, 2006 at 4:38:13 pm
Ok I figured it out, When I exported the project as an Mpeg 2 with the Adobe media encoder, I accidentlly hit the 16:9 aspect ratio, so even though the project was 4:3 it exported to a 16:9, Dang that was a pain! Thanks for the help, you got me thinking!
Joe Bowden
on Dec 22, 2006 at 8:08:22 pm
Aha! I had a feeling it was something like that.
Glad you found it, and thanks for the update.
