Encore won't import 640x480 .avi
COW Forums : Adobe Encore DVD
Desmodromic
on Dec 17, 2006 at 7:10:34 am
I'm trying to archive some old TV stuff at 640x480 resolution, but Encore won't let me import it. Is there a simple solution? Roxio EMC9, Nero and ShowTime have no problem with "TV resolution" .avi files. I hope I didn't spend $315 on software that can't do what the $50 software does.
Any help is appreciated.
Jeff Bellune
Re: Encore won't import 640x480 .avi
on Dec 17, 2006 at 3:22:53 pm
Allowable frame sizes for NTSC video are 720x480, 720x486 and 704x480. Nothing else will work.
You have 2 choices:
1. Re-capture your old content at one of those resolutions (720x480 would be best), or
2. Import your 640x480 files into an editing/conversion program and export out avi or mpg files at one of the accepted resolutions. Then import the new files into Encore.
FYI, the $20,000+ Sonic Scenarist won't accept the 640x480 files, either. Cost of the program is not an indicator of its ability to do anything you want with any format you want. Cost of DVD authoring programs is usually determined by what magic the software can do with compliant files in order to produce stunning finished discs. Nero, Roxio, and others in that price range are limited in that regard when compared to Encore, as Encore is similarly limited when compared to Scenarist.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Desmodromic
on Dec 17, 2006 at 3:55:31 pm
Thanks Jeff, I'll stop banging my head on the wall now! I'll look into an editing program.
-Desmo
