DVD error 16072
COW Forums : Adobe Encore DVD
phocas kroon
DVD error 16072
on Dec 8, 2006 at 2:22:25 pm
After the burning session is almost ready I get a message DVD error 16072 end of file.
I did a search on this forum and saw this problem in Encore version 1.0 and should be solved in 1.01. I use Encore 1.5.
It is a DVD with 12 short movies with a menu without moving background and animated knobs.
No error message during encoding from AVI to Mpeg. No error message during Preview.
Any ideas?
Phocas Kroon
David Garrett
Re: DVD error 16072
on Dec 8, 2006 at 4:17:26 pm
This is lifted from the Adobe forums.
"I'm writing back just to let people know that Neil Wilkes was exactly right, at least for the problem I was encountering: the issue was that I needed to re-size each video/audio pair to make sure they were exactly the same duration. It did come down to a 1 FRAME difference in one of the sequences, so it is important to ZOOM ALL THE WAY IN before you start determining that if the lengths match up or not.
I don't know why the clips would not import at exactly the same duration as when I used Premiere to create them...very odd...nonetheless, thanks Neil for the useful tip, and thanks John for pointing me in its direction."
© 2018 All Rights Reserved
