Looping Video on Title Menu not working
COW Forums : Adobe Encore DVD
ShowMe_TrB
on Dec 8, 2006 at 2:36:37 am
I'm setting up a DVD main menu with a video loop. When I do the preview in Encore DVD 2.0, it's not showing the video looping, only sitting at the first frame. Suggestions?
TrB
Show-Me Tractor Cruise
http://www.showmetractorcruise.com
ShowMe_TrB
It's there now...just not looping
on Dec 8, 2006 at 4:28:11 am
The audio loops like it should...the video doesn't. What do I need to change?
TrB
Joe Bowden
Re: It's there now...just not looping
on Dec 8, 2006 at 5:03:49 am
File > Render > Motion Menus
ShowMe_TrB
on Dec 8, 2006 at 5:17:29 am
I've done that, but it's still only playing 1 time. How do I keep it looping?
TrB
David Garrett
on Dec 8, 2006 at 11:40:50 am
Look to the properties page and change from LOOP ONCE to FOREVER
David Garrett
on Dec 8, 2006 at 11:43:34 am
sorry.. i meant PROPERTIES-MOTION Tab, of the MENU.....
ShowMe_TrB
on Dec 8, 2006 at 2:49:40 pm
I have the Loop #: set at Forever, but it only plays the motion video 1 time when I go to preview...
Getting closer...
TrB
ShowMe_TrB
on Dec 8, 2006 at 2:58:08 pm
Okay...got the video (:23.5 second long) to loop...but now the audio loop begins again, too. Hmmm...it seems like that's almost a step back.
TrB
Joe Bowden
on Dec 8, 2006 at 3:35:05 pm
Audio and video always loop in a motion menu.
What effect are you trying to achieve?
David Garrett
on Dec 8, 2006 at 4:01:54 pm
Are you using a single video/audio stream for the motion menu? if you are then open this up in your video editor and export the video and audio as seperate streams, then drop the video and audio onto the menu as sperate streams.. I know that Encore had a 15 second max duration linitation for video/audio for motion menu assets. The aforementioned trick was how i used to get around this limitation in Encore 1.5, not sure if this is the same with version 2.0
ShowMe_TrB
on Dec 8, 2006 at 4:02:51 pm
I have a line of tractors that is driving by...since the camera was on a mount, it works well to loop the handful of colors I had...makes it look like a continuous tractor parade (our ride is with over 300 tractors).
I've come up with a "poor man's fix," as I created the loop myself on top of the entire music bed. (the music bed didn't have a natural spot to loop itself)
TrB
ShowMe_TrB
FIXED
on Dec 8, 2006 at 4:00:05 pm
I did the easy way out...creating a loop myself with the audio bed underneath...it's a longer file that way, but it loops and works since the audio and the video are the same length.
TrB
David Garrett
Re: FIXED
on Dec 8, 2006 at 4:03:08 pm
sorry.. we posted more or less at the same time.... :-)
