Question Regarding 3-Color Button Problem
COW Forums : Adobe Encore DVD
Retreet
on Dec 7, 2006 at 3:56:43 pm
Hey,
I've been working on a menu for a production I've worked on. A picture of the menu can be found here:
http://img.photobucket.com/albums/v132/fif4lifefif/BushMonsterMenu.jpg
I edit my menus in Photoshop, and for this menu I used a rose stamp for the button highlights. However, the rose is comprised of multiple shades of gray.
Does anybody know how I can seperate the different shades of gray in the rose into three layers so that my button highlight will be at least somewhat close to the actual rose?
-Vince
David Garrett
Re: Question Regarding 3-Color Button Problem
on Dec 7, 2006 at 5:19:21 pm
this may help u.. (http://asvideoproductions.com/doogs/downloads.htm) look to Tut #10 in the Advanced section, u will have to modify and adapt the tut to your own specs.. Just remember that you can only use 3 seperate colour highlights as a max...hope this helps
Retreet
on Dec 7, 2006 at 10:13:15 pm
Great, I'll check that out when I get home. Thanks!
David Garrett
on Dec 8, 2006 at 6:43:03 am
I forgot to mention that you will only be able to use 3 solid colour shades of grey for the rose..
Retreet
on Dec 8, 2006 at 5:27:28 pm
Oh, of course. I just wasn't sure as to how I could make the stamp into three seperate layers, each showing a different shade of gray.
-Vince
