HELP-- No audio on disk (1.5)
COW Forums : Adobe Encore DVD
videoassets
on Nov 30, 2006 at 5:27:52 am
Hope someone's up late. I have audio playback previewing the project, but no audio on the disk. Using ac3 files. No errors when checking project. One menu with two items.
I've got an early call, please help if you can.
Thanks.
Jeff Bellune
Re: HELP-- No audio on disk (1.5)
on Nov 30, 2006 at 11:02:37 am
On what software/hardware DVD players did you test the finished disc?
The Focal Easy Guide to Adobe Encore DVD 2.0
videoassets
on Nov 30, 2006 at 11:40:05 am
I tested several discs with Power DVD (V4) and WMP (V10) on the software side. Also my standalone Panny DVD Recorder. I did solve the problem after I discovered a tip surfing somewhere to set the subtitles to off (there weren't any subtitles in the project). I think it was originally set to 1 or 0. Shouldn't the Check Project alert you to this?
I wasn't very optimistic, but it actually worked.
Thanks Jeff.
