How do I make a button that will go to the next menu?
COW Forums : Adobe Encore DVD
dax702
on Nov 9, 2006 at 10:37:14 pm
I'm new to Encore DVD, watched the Lynda.com training video and am doing pretty well so far. I'm having trouble figuring out how to have a simple arrow graphic (from the library) be the button that goes to another submenu. Can someone tell me how to do this?
Joe Bowden
Re: How do I make a button that will go to the next menu?
on Nov 9, 2006 at 11:33:51 pm
Drag the button from the Library into an open menu.
Convert it to a button.
With the button selected, go to Properties, click in the Links field and link it to the menu you want.
dax702
on Nov 10, 2006 at 12:29:50 am
I got it, thanks! I also discovered something else too. If I want to use highlight group 2 for that specific button, I could only change it to (=2) IN photoshop. couldn't figure out how to change it in Encore. In other words, if all of my chapter selection subpictures are yellow when selected, I wanted the button for the next menu to be dark red when in normal state, and brighter red when selected. The only way I could do it was to go in photoshop and change the (=1) to (=2).
Which leads me to ask what the "Highlight:" option is in the properties panel? Its options are Group 1 and Group 2
Joe Bowden
on Nov 10, 2006 at 6:51:12 am
Don't confuse the subpicture layer number (=1, 2, & 3) with the highlight groups- they two are different things.
Each highlight group can have differerent subpicture layer numbers (unique =1, 2, & 3 values). You set the highlight group in Button properties (select the button, then go to the Properties panel).
