End action skip.
COW Forums : Adobe Encore DVD
Tim Bond
End action skip.
on Oct 22, 2006 at 2:53:29 pm
Hi all,
I have a first play vid clip that is set to go to a playlist as it's end action. The playlist then end actions to the first Menu. However when i try this the first vid clip plays but then misses out the clips of the playlist and jumps straight to the first menu. Is this a quirk of the playlist function? Do I need to end action the list of clips if the playlist to each other and have a daisy chain of vid clips instead of using a playlist? Any thoughts?
Jeff Bellune
Re: End action skip.
on Oct 22, 2006 at 3:25:29 pm
Check to see that you didn't set an override for the first video clip.
The Focal Easy Guide to Adobe Encore DVD 2.0
© 2018 All Rights Reserved
