Noise on Video after transcoding
COW Forums : Adobe Encore DVD
PRgraphist
on Oct 8, 2006 at 4:01:38 pm
I allready make DVD from a video captured (in premiere 1.5) from VHS tape when I edit a little bit, I Export to a .AVI and make a little menu to the DVD When I play the video its look like noisy and have scanline crossing the screen, It look like a 70's video. somebody have this problem before?.
Vincent Becquiot
Re: Noise on Video after transcoding
on Oct 9, 2006 at 4:06:07 am
The noise maybe normal, since DVD compression really doesn't do well with already noisy input, which would be the case of a VHS.
The scan lines you are referring to maybe a wrong field order, that is usually accompanied with "jerkiness" in motion areas. You will need to know whether you imported your footage in lower or upper field first.
Vince
PRgraphist
on Oct 10, 2006 at 5:48:00 pm
I render the video from Premiere with the Lower field first
