Transcoding setting question
COW Forums : Adobe Encore DVD
on Oct 7, 2006 at 6:57:09 pm
I Have a 2 hours NTSC DV video with one simple very Menu and I like to fit it into a DVD-R 4.7GB single layer, What the best setting to do this? does this media is the best?.
thanks in advance
Neil Wilkes
Re: Transcoding setting question
on Oct 10, 2006 at 3:02:18 pm
Use Encore's "Automatic" setting.
2 hours is pushing it for a single layer disc in terms of quality, and will result in a bitrate of 4.82 average with VBR encoding.
(Encore will automatically use VBR encoding at anything under 6Mb/sec as a rough guide)
Whether or not this is acceptable will depend on your source footage.
If there is a lot of rapid motion & fast stuff, or heavily detailed scenes, it might not be sufficient.
To test, try taking the busiest clip you can & transcode it using the following settings:
VBR 2-Pass
Peak Bitrate = 9.41Mb/sec
Average (Target) bitrate = 4.82Mb/sec
Write to an RW disc, and see what it looks like.....
© 2018 All Rights Reserved
