Add links to external sites
COW Forums : Adobe Encore DVD
Gochos
on Oct 5, 2006 at 9:54:52 pm
Hi
I was wondering is it possible to add a link to an external website in Encore DVD?
Thanks in advance
Costas
Jeff Bellune
Re: Add links to external sites
on Oct 6, 2006 at 2:21:02 am
Not with Encore alone. You should give Sonic's eDVD a try.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Gochos
on Oct 6, 2006 at 8:38:58 am
Isnt Sonic Edvd Encores competitor?
Can i add links to menue with edvd and then transfer to encore?
Jeff Bellune
on Oct 6, 2006 at 11:59:02 am
[Gochos] "Isnt Sonic Edvd Encores competitor?"
No. It supplements Encore by performing a task that Encore can't do yet.
[Gochos] "Can i add links to menue with edvd and then transfer to encore?"
I don't know if you finish your Encore project first and then bring the DVD folders into eDVD or vice versa. If they have a demo you should try it out.
-Jeff
John Cuevas
on Oct 6, 2006 at 2:26:35 pm
It actually works very easy, very intutitive.
You create in encore you menus. Button 1 links to videoA, Button2 Video B. Button 3 you want to link to a outside source, say a webpage, pdf.... You create a button, then link it to a blank timeline.
The next step is to create a DVD Folder from Encore. Then open eDVD, after picking your video.ts files, it will have a pulldown for each button in your menu. Select the button, then just follow the pulldowns to establish what you want to do.
After that all you do is burn the DVD and voila, DVD-Rom. The only drawback is that you need Interactive Player to access the DVD rom features. For computers that don't have this, it will install upon being put in the DVD drive, but some people get all freaky about stuff like that.
Gochos
on Oct 6, 2006 at 5:26:08 pm
Thanks John
Is the DVD burnt in encore?
John Cuevas
on Oct 6, 2006 at 5:57:59 pm
It can be.
There is a place to link in the burning section to the files. Or you can use the Nero software supplied by eDVD to burn it. Both ways work equally well.
