To pal or ntsc that is the question?
COW Forums : Adobe Encore DVD
roenld
on Sep 22, 2006 at 5:17:26 am
Hi there !
we are down under PALies and we are sending a festival entry DVD to the US and not sure whether it should be PAL or NTSC - and since the master is PAL I am guessing that Encore will not "standards convert" - any advice will accepted with open arms!
Neil Wilkes
Re: To pal or ntsc that is the question?
on Sep 22, 2006 at 9:59:53 am
95% of all PAL machines will play an NTSC disc.
95% of all NTSC machines will NOT play a PAL disc.
If you are sending to the USA, it must be NTSC. Simple.
"Standards Conversion" of an authored disc is next to impossible to do.
Menus are a different resolution & PAR.
Video is a different resolution & frame rate.
You must rebuild as an NTSC project - redesigning all menus, and converting all Video.
Sorry about this - but that is the way it is.
Vincent Becquiot
on Sep 27, 2006 at 3:27:39 am
The best way to convert to NTSC using a software based solution is Canopus Procoder IMO.
Vince
Neil Wilkes
on Sep 27, 2006 at 6:13:42 pm
Which will not do the menus.
