remote control from Menus
COW Forums : Adobe Encore DVD
Levels
on Sep 11, 2006 at 7:22:27 pm
I have a question regarding using the remote while on a menu.
Lets say I have 4 menus. On menu "2" I would like to hit "menu" on the remote and go back to menu "1". While on Menu "3" I would like to hit "menu" on the remote and return to menu "2," and so on. I know that you can do this on a track or set it globally, but that isn't exactly what I want.
I'd like to know if I could do this?
Thanks in advance.
T
Jeff Bellune
Re: remote control from Menus
on Sep 11, 2006 at 8:43:42 pm
You can't enable the Menu Remote property from a menu. That is a timeline property.
All DVD players function this way. If a video is playing (an Encore timeline), then the Menu Remote property for that timeline determines what happens when the Menu button is pressed. If the Title button is pressed, the Title Button property for the Disc determines what will happen next. The menu and title buttons should only take you back to the point where playback was interrupted if they are pressed when a menu is displayed.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
