ghost image
COW Forums : Adobe Encore DVD
seminewbie
ghost image
on Sep 2, 2006 at 9:34:27 pm
I just lost the biggest authoring contact I have ever obtained to an error which i just can't figure out. I am using adobe encore and every time I attempt to transition between clips on the dvd the disc pauses and leaves a "ghost image" of the final visible frame from the previous clip before moving to the next clip. This only seems to happen when the transition is a fade to...and out of...black. I tried adding extra frames of black to the beginning and end of all clips to no avail. To say that I am disappointed is to put it mildly. I am obviously not under any time constraints here because I have already blown my opportunity but if anyone has any ideas as to how I can avoid this in the future it would be appreciated.
Thanks;
Dan
Joe Bowden
Re: ghost image
on Sep 3, 2006 at 1:49:06 pm
What version of Encore are you using?
seminewbie
Re: ghost image
on Sep 3, 2006 at 3:47:16 pm
Encore 1.5. My system is P4 2.8 1.5 Gig Ram and i am burning using a sony dual layer drive.
TNX.....Dan
Joe Bowden
Re: ghost image
on Sep 4, 2006 at 4:49:30 pm
You need to go back to Premiere, uncheck "optimize stills" in the AVI export dialog, and then re-export. Or export an MPEG-2 from Premiere.
"Optimize stills" is supported in Encore 2.0.
seminewbie
Re: ghost image
on Sep 4, 2006 at 10:24:05 pm
Thanks Joe......Makes sense...I'll try it at my earliest opportunity.
Dan
