How do I see where Encore placed the layer break using IFOedit?
COW Forums : Adobe Encore DVD
tommmm
on Aug 22, 2006 at 5:23:32 pm
Anyone know how to use IFOedit to see where Encore placed the layer break on a DL disc? I saved a DVD folder to my HD, opened it in IFOedit, but don't see where it shows the layer break point.
Neil Wilkes
Re: How do I see where Encore placed the layer break using IFOedit?
on Aug 23, 2006 at 11:29:05 am
Launch IFOEdit, and then open up the IFO files in it.
The one(s) that we should be looking at are the VTS_xx_x.IFO files.
One of these - when you first open the IFO file (do not select anything at all in the upper half of the window) will clearly state where the break is.
You will know you are in the right screen when you can see across the top the wording
"VTS Overview" in the decription column.
If you get stuck, you can always send me the IFO files and I will tell you where the break is.....
