After files used in a menu have been transcoded in Encore. Can I delete the source AVI files?
COW Forums : Adobe Encore DVD
tommmm
on Aug 11, 2006 at 7:27:36 pm
I'm wondering if after creating a menu, transcoding all the files and saving the encore project, can I then delete the source AVI files? Or are they still used and needed?
graham quince
Re: After files used in a menu have been transcoded in Encore. Can I delete the source AVI files?
on Aug 13, 2006 at 7:21:17 am
As far as I know, those avi files are no longer used. Encore creates quite a big folder for the project.
Although, I normally wait until I've burnt the final DVD before deleting anything though. Mor often than not, the first DVD highlights some glitch, I've left in, that requires the orginal files.
As a test, you could make a copy of your Encore project, then try moving the avi files, and then opening the copied Encore project to see what happens.
Graham
http://www.quinceweb.com - web design
http://www.shiveringcactus.bravehost.com - Free FX for amateur films
