Highlight Buttons
COW Forums : Adobe Encore DVD
awhansen01
Highlight Buttons
on Aug 5, 2006 at 8:43:56 pm
I am using Encore DVD and I created a DVD, and in the menu's, the buttons do not work on a DVD player. But, they do work on the computer. Even the buttons that I used from Encore don't always work. They show up as vertical lines along the side of the button. What is wrong?
awhansen01
Re: Highlight Buttons
on Aug 5, 2006 at 10:51:55 pm
and I have the menu as 16x9, i have a low quality dvd player that i can put the dvd in, the highlights work, but the menu is fullscreen
Neil Wilkes
on Aug 6, 2006 at 10:45:02 am
Fullscreen sounds like the player is not picking up the aspect ratio correctly to me.
I have found that Encore 2 is perfectly fine with 16:9 display, even if mixed with 4:3 content.
What is not standard though is the way both players & TV sets handle this.
As an example.
If my old CRT Widescreen set is yturned on & allowed to set itself - all aspect ratio changes happen automatically. As soon as I over-ride one and set it from the remote - it will not switch automatically again until I turn off & back on.
Check the TV/DVD player settings here.
Neil Wilkes
on Aug 6, 2006 at 10:45:39 am
What player?
What TV?
Have you set the opacity correctly in the Menu Colour Set?
awhansen01
on Aug 8, 2006 at 12:48:00 am
i figured it out, it was because the menu was in 16x9, i changed it to 4x3 and it worked fine
