Using Encore DVD 2.0 menus in Premiere 2.0
COW Forums : Adobe Encore DVD
polypixel
on Aug 3, 2006 at 7:40:02 am
Hello there!
i'm relatively new to DVD authoring stuff.
i've installed Trial Premiere Pro 2.0, so there are not any DVD menu presets installed (Templates list is empty in
DVD Layout menu) as it comes along with a bunch of them in full version.
So i've installed Encore 2.0 to make a simple menus by myself there and use them in Premiere 2.0 for authoring DVD pursposes
But i dont know how to export (and where to locate in Premiere ) files prepeared in Encore..
ive searched in help file a lot, but with no luck..
any little help is very appreciated..
Thank You alot.
Joe Bowden
Re: Using Encore DVD 2.0 menus in Premiere 2.0
on Aug 3, 2006 at 1:48:57 pm
The Premiere Pro trial doesn't write DVDs.
You can use the Encore trial (or Encore itself), but you construct the DVD project from within Encore. So your workflow would be:
1. Capture video in Premiere
2. Edit video in Premiere
3. Export Premiere sequence to AVI
4. Import AVI into Encore
5. Create DVD project in Encore with menus, etc.
Hope it helps,
Joe
Joe Bowden
on Aug 3, 2006 at 1:49:39 pm
Oh, and of course:
6. Burn DVD from Encore
polypixel
on Aug 3, 2006 at 7:22:00 pm
Oh thanks a lot for suggestions, I'll definitely give a try..
but isnt there a way, to import a menu from Encore, and make authooring stuff in Premiere itself ?
Joe Bowden
on Aug 4, 2006 at 10:05:18 pm
Not sure about this, but I think you can only use the menus provided in Premiere if you are exporting to DVD from there.
That said, as I mentioned earlier, the trial version of Premiere cannot export to DVD.
