operating system error: number = 0x00000020????? HELP???
COW Forums : Adobe Encore DVD
tonyrain
on Aug 1, 2006 at 12:58:42 am
When trying to build a DVD in Encore 2, after I check project, with no errors, and after I click build DVD, it starts to render but then gives this error:
operating system error: number = 0x00000020 - The process cannot access the file becasue it is being used by another process.
I have quit evey other program and restarted but nothing works. Anyone know what this means. Anyone know what I can do?
Thanks.
Mylenium
Re: operating system error: number = 0x00000020????? HELP???
on Aug 1, 2006 at 10:23:33 am
Sounds like you have a DVD-drive that Encore doesn't like or some system driver/ tool (e.g. Demon tools) is locking your drive. could be a million things. The immedfiate solution would be to create an image file from Encore and burn it using another tool.
Mylenium
[Pour Myl
cow
tonyrain
on Aug 1, 2006 at 6:21:29 pm
I actually found this solution in another forum and it works!
NEW SOLLUTION:
What i did to solve probelm:
I belieave this problem is originated from clicking animate buttons and then later un-clicking animate buttons. This corupts the menus that used to have animated buttons. The sollution is as follows.
1) Save project as a new name.
2) Save all menus as templates using Menu/save as template.
3) Delete menus 1 at a time and replace with the templates you saved.
4) Re-link all buttons.
Adobe needs to address this issue as it seems to be happening to anyone who clicks animate buttons and then later un-clicks them.
Thanks for your help!
