Subtitles on DVD are not reflecting changes made in Encore
COW Forums : Adobe Encore DVD
Phil Grimpo
on Jul 14, 2006 at 10:10:31 pm
I had a subtitle text script that I imported to Encore. Then I made all my spacing changes, etc. and had to make some text changes, spelling changes, etc. Most all the changes took, but a couple. For example, when I view the subtitle in Encore, it looks fine, but then when I make the DVD and view it, either words are just missing, or lines never appear. This only happens like 4 times throughout the DVD. Any ideas why this is happening? I've tried clearing the cache, etc. with no luck. I've checked the build and there are no errors. Any ideas on why some of these changes are working fine in Encore, but not when played on the DVD? (I have tried a couple different players)
-Phil
_______________________
Phil Grimpo
Inspirmedia
http://www.Inspirmedia.com
Joe Bowden
Re: Subtitles on DVD are not reflecting changes made in Encore
on Jul 15, 2006 at 3:57:30 pm
Try selecting all of your subtitle clips, go to the Character panel and change the font, then (wait for it), undo. Burn another DVD (you are using RW, correct? if not, do so...), and see if that solves the problem.
Phil Grimpo
on Jul 15, 2006 at 5:12:53 pm
I'll try that. Why do you say to use RW?
I use Tai Yuden DVD-R Disks.
-Phil
Jeff Bellune
on Jul 15, 2006 at 5:37:38 pm
[Phil Grimpo] "Why do you say to use RW?"
So that you don't make any coasters while you test/experiment.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Phil Grimpo
on Jul 16, 2006 at 11:51:43 am
OH. Gotcha. I thought you were meaning for integrity purposes. Your trick worked! It looks like the subtitles "stuck" this time. Thanks!
-Phil
Phil Grimpo
Inspirmedia
