Button Transitions question
COW Forums : Adobe Encore DVD
Gene Colburn
on Jul 4, 2006 at 4:35:11 am
Can someone tell me what the function options of this are supposed to be? You would think that an Encore help search would find info about a Tabbed property function, but nothing found. I am sure it relates to an annimated button action, but going to the Buttons property tab that shows this function calls up no action that I can see. I was hoping it would allow some button fades with cursor over menu areas. Just not sure, and no can find info.
David Garrett
Re: Button Transitions question
on Jul 5, 2006 at 11:55:11 am
what it means is that you can link your button to play a timeline clip and then use the "Button Transistion" option to play a small .avi file of your choosing which in turn will then play the choosen video file that the button was orginally linked to......
Gene Colburn
on Jul 5, 2006 at 4:48:40 pm
Thanks Dave
I need to investigate this further as it sounds like it could be useful.
David Garrett
on Jul 7, 2006 at 10:58:52 am
this should help you a little bit more.. just a brief tutorial on the transistion function of Encore (http://asvideoproductions.com/doogs/encore2%20tut002.zip)
Gene Colburn
on Jul 8, 2006 at 8:22:08 am
Thanks David
Kinda slick. I was assuming it could be used with sound effects, but picture worth thousand words.
David Garrett
on Jul 8, 2006 at 9:54:55 am
you could just use a copy of the menu and then add some audio or soundFX to this in your video editor and then export as .avi
