vobs
COW Forums : Adobe Encore DVD
john culleton
vobs
on Jun 26, 2006 at 10:02:09 am
can anyone suggest best way to get vobs into encore2 please
Jeff Bellune
Re: vobs
on Jun 26, 2006 at 12:40:26 pm
Use a DVD ripping tool to rip the video into .m2v and .ac3/.wav files
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
john culleton
Re: vobs
on Jun 26, 2006 at 8:24:19 pm
encore doesn't accept the m2v file, green screen and it re encodes
john culleton
Re: vobs
on Jun 26, 2006 at 8:28:22 pm
Encore doesn't like the m2v files, green screen and it re encodes
Jeff Bellune
Re: vobs
on Jun 26, 2006 at 8:53:51 pm
What is the frame size/frame rate of the ripped .m2v files? Can you play them separately in a media player?
What program did you use to rip? Settings for the rip (raw, demux, etc.)?
-Jeff
john culleton
Re: vobs
on Jun 26, 2006 at 10:47:53 pm
files are ntsc, i used DVDLab to demux vobs to m2v & ac3, they play fine in all other apps
Jeff Bellune
Re: vobs
on Jun 26, 2006 at 11:56:21 pm
Encore is fussy about .m2v files. I still need to know the frame size and frame rate.
-Jeff
john culleton
Re: vobs
on Jun 27, 2006 at 12:15:57 am
720x480 and 29.97fps
Jeff Bellune
Re: vobs
on Jun 27, 2006 at 1:53:04 am
That rules out 704x480 and/or something other than 29.97 fps.
Do you have any version of the DivX codec installed on your system? Older reports of other possible conflicting software include more recent MS Intellipoint drivers (v. 4.1 should be OK).
Do you have Premiere Pro 2? It has the same playback engine as Encore, so you could import the m2v files into Premiere and see if you can play them back properly in PPro. If they work OK in PPro, then export DV or HuffYUV avi files from Premiere for use in Encore.
Failing that, I would recommend converting the m2v files to DV or HuffYUV avi files using dvd2avi and then importing those into Encore.
-Jeff
john culleton
Re: vobs
on Jun 27, 2006 at 12:04:38 pm
no problem with PAL files, i think this is a bug in ver2, i read someone has the same issue, but not with 1.5
Jeff Bellune
Re: vobs
on Jun 27, 2006 at 12:39:08 pm
NTSC .m2v files work great on my system (and many others). If it was a bug, it would be reproducible across multiple platforms, which it is not.
Since you didn't answer any of my questions from my last post, can I assume you are done with NTSC files and will stick with PAL, and that the issue is resolved?
-Jeff
john culleton
Re: vobs
on Jun 27, 2006 at 1:47:14 pm
ok must be me, dont have DivX or PPRO, i'll try DVDtoAVI for the NTSC's
Aanarav Sareen
Re: vobs
on Jun 27, 2006 at 6:11:33 pm
[Jeff Bellune] "NTSC .m2v files work great on my system (and many others). If it was a bug, it would be reproducible across multiple platforms, which it is not."
Ditto to this statement.
I use M2V fies generated from CinemaCraft encoder every session and it works great!
Aanarav Sareen
premiere@asvideoproductions.com
john culleton
Re: vobs
on Jun 28, 2006 at 11:29:54 am
other users are having this problem....
this message is from the Adobe forum
NTSC Mpegs Reading Green!!
"All of my NTSC mpegs that work fine in Encore 1.5,come up as a Green screen when I import them to Encore 2.0..They appear fine in Adobe bridge,play fine in all other platforms,it's just Encore 2.0 that doesn't see them.I don't seem to be able to go to 'Interperate footage'either.
Any ideas?..This is really holding us back from doing what we bought the new Encore for"
there are a couple of others with green screens there too
herojig
Re: vobs, that's easy!
on Jun 28, 2006 at 1:55:14 pm
Uh guys, i just drag them into the project window, works great. set do not transcode (but it defaults to that). I use this technique sometimes when in premiere pro1.5, using canopus procoder to quickly get a video into an encore dvd project. canopus does the job much faster. but maybe i missed something here :)
jigs in nepal.
