serperating TS.bup from TS.ifo in the ECC block?
COW Forums : Adobe Encore DVD
DeaditteX
on Jun 19, 2006 at 10:21:43 pm
Okay so, it there a way to set it so that when I burn the disc, the video_ts.inf and bup are set to record to seperate places, is this in user settings or should I concern myself more with the actual burning program... zulu is what we use to burn the DVD's we make them in encore.
I guess they consider me the resident adobe expert around here because I can run AE and photoshop and audition(kinda) so now they just assume I know all the prooducts... which I should but sometimes it is like speaking manderan to some one who speacks cantonize, ...
Neil Wilkes
Re: serperating TS.bup from TS.ifo in the ECC block?
on Aug 5, 2006 at 2:19:46 pm
Your buring software should do this automatically.
If you are creating a folder from Encore, then avoid Nero as this is one of those that does not set the required gap between the 2 files.
There may be others as well.
If your burning software cannot handle this, then write from Encore as an image - or directly to DVD.
