Encore 1.5: Colorblob in place of subpicture
COW Forums : Adobe Encore DVD
rlyman
on May 24, 2006 at 5:18:41 pm
I've created an image that will act like a curser to the highlighted button. However, when I go back to Encore from photoshop, the image has turned into a color blob. The shape is maintained, but is filled with a solid color. Any suggestions, anyone?
R
Jeff Bellune
Re: Encore 1.5: Colorblob in place of subpicture
on May 24, 2006 at 6:15:27 pm
You can't do much with subpictures. They can be shaped, single-color and partially/completely transparent but that's it. It's not Encore's fault - that's how the DVD spec is set up to handle subpictures.
You can trick the audience into thinking that you have fancy cursor highlights by using a combination of multiple identical menus and auto-activate buttons.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
rlyman
on May 25, 2006 at 5:02:14 pm
Thanks Jeff...
How would I go about doing that?
David Garrett
on May 26, 2006 at 6:32:47 am
look to Tutorial #9 of the advanced section of my site http://www.sitesled.com/members/doogs/downloads.htm it will show you how to go about it. Just adapt the process for your own needs (tutorial is for Encore 1.5)
rlyman
on May 31, 2006 at 3:45:53 pm
Is the a mistake with the url? The link isn't working...
R
David Garrett
on May 31, 2006 at 4:04:38 pm
the link does work.... it's just that sitelsed has been down for over a week now.. i am looking at some paid hosting options at the momment...
sorry about that
