Encore 2 Bug?
COW Forums : Adobe Encore DVD
frank weber
Encore 2 Bug?
on May 24, 2006 at 2:57:03 pm
Hi. I open a file in Encore-2 created in Encore-1.5 and it works fine. However when I try to export a DVD-folder using it I get an error message half way through and it quits.
The project also takes alot longer to open in 2 than it did in 1.5. Strange?
I'm on Windows XP.
The error mesage is: Internal Software ErrorVobulatorTitleplannerCVOBUPlanner.cpp,line 133
Is anyone else experiencing this?
Please Help!
The Answer is 42.
Jeff Bellune
Re: Encore 2 Bug?
on May 24, 2006 at 3:07:00 pm
Some things to consider:
1. Have you added any chapter points at or near the end of any timelines to assist the audience with skipping from timeline to timeline? Remove them if you have. Encore 2.0 does this automatically for you with a hidden chapter marker at a timeline's end.
2. Do you have any assets that are less than 2 seconds long?
3. Do you have any looping menus less than 1 second long?
4. Do you have any chapter markers spaced less than 2 seconds apart?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
frank weber
Jeff, I love you! I know that's weird, but I do.
on May 24, 2006 at 4:19:52 pm
It's the chapter markers.
How do you ad them in Encore-2 though?
The Answer is 42.
Jeff Bellune
Re: Hmmm. Is there luggage involved?
on May 24, 2006 at 6:11:45 pm
Hi Frank,
Which chapter markers? The ones at the end of the timeline or the ones placed closely together?
Deletion of your markers at the end of the timeline should fix that problem; the closely-spaced markers may be trickier to solve. What are you trying to accomplish?
-Jeff
frank weber
Ye speaketh the truth!
on May 25, 2006 at 9:17:09 am
Removing the markers worked and you were right: Encore-2 seems to skip to the end of clips perfectly by default, so no markers needed.
-I use encore to author my showreel. (I'm an animator)
I was about to reinstall windows when you posted that tip.
Thanks a again.
The Answer is 42.
