best file type to import
COW Forums : Adobe Encore DVD
David Carey
on May 16, 2006 at 3:33:30 pm
I am recieving movie(s) from a Discreet Edit system. What is the best file structure for them to export in order to import into Encore? I have found that a full frame/uncompressed avi is too big to import into Premiere on my stystem and I would imagine the same to be true for Encore.
Is there a compression that is best for retaining a good image and yet is managable in size?
Please advise.
Joe Bowden
Re: best file type to import
on May 16, 2006 at 3:49:26 pm
Try Huffy-YUV. Both the Discreet system and your Encore system will need the codec installed.
Jeffrey Gould
on May 16, 2006 at 10:59:07 pm
I had a major problem with Huffy...crashed my project and wouldn't let me render motion menus. I finally tech support and they said the cpu is maxing out because it's trying to decompress the huffy's and trying to compress the mpeg2's. I used DV files and all worked fine.
Jeffrey S. Gould
Action Media Productions
Joe Bowden
on May 17, 2006 at 2:45:42 am
I've used Huffy many times...no problems yet.
