How to define which menu is the main Menu??
COW Forums : Adobe Encore DVD
frank weber
on May 2, 2006 at 1:15:21 pm
How to define which menu is the main Menu so that when the disc starts it knows where to start?
Thanks.
The Answer is 42.
David Garrett
Re: How to define which menu is the main Menu??
on May 2, 2006 at 1:31:01 pm
if you have a short "intro movie" then set the "intro's" end action to go to the menu that you have specified as the "main menu", or if you just want the speicified "Main Menu" to show first after the disc has been inserted then just right click on this menu and then select "set as first play"
Joe Bowden
on May 2, 2006 at 3:15:46 pm
Set the menu as Title menu in Encore (title menu is usually the main menu for the DVD).
David Garrett
on May 2, 2006 at 5:20:10 pm
is this how it's done in Encore 2.0 then Joe???
Joe Bowden
on May 2, 2006 at 9:14:50 pm
It's important to differentiate between First Play and Title Menu.
First Play is the item that plays the first time a disc is inserted into the player. It can be a timeline, chapter playlist, slideshow, or menu.
Title menu is usually the the parent menu of all other menus. The title menu is the one you see when you press the Title or Top button on your DVD player. It often contains links to other menus and submenus on the disc- ideally you can get to any menu from here with only a few button presses.
frank weber
Thanks Guys!
on May 5, 2006 at 9:53:02 am
Thanks.
The Answer is 42.
